kegger intake mod
Old Apr 22, 2008 | 11:06 PM
dodge@1997's Avatar
dodge@1997
Default RE: kegger intake mod
I had my Battery disconnected for two days. This will have reset the right?.?.?
Old Apr 23, 2008 | 08:29 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: dodge@1997
Reset the what? If you're asking if it has reset the PCM, then yes.
Old Apr 24, 2008 | 10:59 PM
dodge@1997's Avatar
dodge@1997
yes, I was talking about the PCM. Sorry one should not type will very tired.
Old Apr 25, 2008 | 09:52 AM
steve05ram360's Avatar
steve05ram360
disconnecting the battery for about 5 minutes will reset the pcm. give it a couple of days to relearn the motor after you reconnect it. usually 300 or so miles with a couple of cold start cycles will do it.
Old Apr 28, 2008 | 02:38 AM
Slomojo's Avatar
Slomojo
bumpidy
Slomojo's Avatar
Slomojo
bump
Old Apr 28, 2008 | 02:42 AM
Slomojo's Avatar
Slomojo
bump...
So yeah, back to the topic... What's a good tool to use for evening and smoothing things up as the reciprocating saw I used made a slanted cut in a set of runners?
Old Apr 28, 2008 | 07:41 AM
WD OPN Throttle's Avatar
WD OPN Throttle
dremel
Old Apr 28, 2008 | 11:24 AM
Slomojo's Avatar
Slomojo
I burned two of those out, anything else? I already burned 2 of those out and now I have to exchange for a new one.
Old Apr 28, 2008 | 11:31 AM
steve05ram360
I used a rotozip with a cutoff wheel... craftsman has a mandrel that is pretty tough where you can use the dremel cutoff wheels on it. worked great. wear safety glasses... they break easily.
