180 Degree Thermostat
Old Apr 19, 2008 | 06:26 PM
HammerZ71's Avatar
HammerZ71
Default RE: 180 Degree Thermostat
Two stage Jet 180* for the 318 and 360 guys are not near what the Hemi one costs (don't ask me why the Hemi one is $30) readily available from a number of sources for under $15!!!
Also, it's a mod that is VERY beneficial to those with other mods that "lean out" the A/F mix, such as CAIs, Headers and especially tuners that advance the timing. All those mods each work to lean you out a little. You put them in combo and you are really running lean, maybe not quite CEL lean, but lean non the less. Guys with those mods should really have the A/F ratio checked, I was very close to CEL lean with all the above mods. The cooler statrichened me up towhere itbrought me very close to stock specs for A/F ratio.
Old Apr 19, 2008 | 06:33 PM
RamItOne's Avatar
RamItOne
ORIGINAL: kowboydmac
I would just keep the stock setup instead of going with a 30 dollar two stage.
25 in spark plugs, synthetic mobil1, mr gasket air cleaner, etc.
yep either buy the 2 stage or dont buy one at all. the only reason im looking at it is because i live in the desert and then will be in Fla.
25 bucks for all that, man i need to shop where you shop lol
hammer maybe the hemi needs two t stats just like it need double plugs for its picky *** to run right
Old Apr 19, 2008 | 06:34 PM
kowboydmac's Avatar
kowboydmac
LOL no I didn't mean it all for 25, just individually. Yeah I just moved up from Florida to West Virginia (talk about a culture shock). Where you moving too?
Old Apr 19, 2008 | 06:38 PM
RamItOne's Avatar
RamItOne
yeah i knew what you meant....
back to my hometown jax...
you were prob in south fla for there to be a huge culture shock in virginia, north fla can be a lil neck...
hell skynyrd is from jax
Old Apr 19, 2008 | 07:42 PM
kowboydmac's Avatar
kowboydmac
ORIGINAL: RamItOne
I lived in Kissimmee, worked at Disney (thus the sarcastic culture shock comment) and a Timeshare, hung out in Polk County (Lakeland, Winter Haven, Frostproof).
ORIGINAL: RamItOne
So is Tom Petty
Anyway, do you have a specific site for the two stage your looking at?
Old Apr 19, 2008 | 07:50 PM
RamItOne's Avatar
RamItOne
i believe all of the jet t stats are 2 stage, i had a heckcuva time finding one for my model year/engine so good luck.. just google jet 180 t stat and hopefully some of the sites will have em or just go to jets website and click on dealers
