Interior Painting?!?!
Old Apr 20, 2008 | 07:05 PM
johnnyrocket5363's Avatar
johnnyrocket5363
Default Interior Painting?!?!
I have a parts truck with a 4-door cab (I have been looking for one for months), the same exterior color as mine. The only problem is, the interior is a light grey, but I prefer a darker color (hides dirt better). I bought the expensive fabric and vinyl paint and test sprayed a few parts, but they aren't holding the paint very well. I have used various methods, including as soap and water, rubbing alcohol and Sno-Bol (hydrochloric acid), to apparently no avail. Am I missing something? Any suggestions?
Old Apr 20, 2008 | 08:14 PM
RM_Indy's Avatar
RM_Indy
Default RE: Interior Painting?!?!
Adhesion promoter.
When I painted my interior, the overhead console and airbag control cover (box on floor below dash) were a real PITA. Gauge bezel, dash trim ring, door pulls, power controls and hvac vent vanes took the paint fairly easily with the promoter. Overhead console had reactions with the paint and promoter but eventually worked on 2nd retry. The airbag control cover I must of painted it 5 times before it finally worked.
Old Apr 20, 2008 | 09:28 PM
CySlyde's Avatar
CySlyde
Havn't tried it on dodges yet, but I would assume it's the same material as most other vehicles... adhesion promoter and a good clean surface will really go a long way. I usually use a almost dry rag of mineral spirits to clean it, then let it sit for a day. havn't had an issue with anything I've done to date.
the interior dies are worthless. I have never seen one go on in a good even coat, or better yet stick for an extended period of time.
