Deep Trans Pan
Old Apr 22, 2008 | 11:10 PM
  #21
RamItOne's Avatar
RamItOne
Default RE: Deep Trans Pan
straight from the website
can be installed without removing factory shroud on Dodge Ram
http://moesperformance.com/index.php...products_id=15
Old Apr 22, 2008 | 11:49 PM
  #22
phlash_riot's Avatar
phlash_riot
as for a fan for the tranny cooler. if you mount an aux cooler in front of the radiator should there be enough air flow across it while driving even at low speeds to be able to cool it amply? and not need and additional pusher fan?
Old Apr 22, 2008 | 11:54 PM
  #23
RamItOne's Avatar
RamItOne
yes, but you might as well get the tranny cooler with fan..
Old Apr 22, 2008 | 11:55 PM
  #24
padodgeram's Avatar
padodgeram
ORIGINAL: phlash_riot
Mine works fine , ill fine out how they do this summer , look in my gallery you will see my custom fan shroud with dual e-fans pulling 2500 cfm , fans kick on at 200 or comes on with defrost /AC...
Old Apr 23, 2008 | 12:15 AM
  #25
RamItOne's Avatar
RamItOne
i like the e fan that i posted, 3300 cfm and has an adj thermostat as well as a manual switch
