ACCESSORY POWER- 2001 1500 RAM / GASOLINE
Old Apr 27, 2008 | 12:15 PM
robert6632's Avatar
robert6632
Default ACCESSORY POWER- 2001 1500 RAM / GASOLINE
HI THERE,
GOT MY 75 WX ST CB INSTALLED. I AM TRYING TO FIND AN ACCESSORY WIRE TO TIE IN THE POWER. I HAVE IT ON A HOT RIGHT NOW . ANY IDEAS WHERE THE BEST PLACE TO TIE INTO AN ACCESSORY CONTACT WOULD BE?
SO IF I FORGET AND LEAVE IT ON,IT WILL SHUT OFF WHEN I PULL THE KEY.
ALSO,IDEAS ABOUT RUNNING THE ANTENNA CABLE . I HAVE A MAG MOUNT RIGHT NOW AND THE CABLE GOING THROUGH THE DOOR SEAL.
THANKS, ROBERT ...ELKO,NEVADA
Old Apr 27, 2008 | 12:49 PM
1980blackfiveoh's Avatar
1980blackfiveoh
Default RE: ACCESSORY POWER- 2001 1500 RAM / GASOLINE
I powered my satilite radio from a wire behind the CD player. I ran my CB antenna wire through a gromet in the door piller. I put my CB on a 12 volt plug so I could remove it when I'm not travelling with fellow RVers.
Old Apr 27, 2008 | 01:39 PM
dhvaughan's Avatar
dhvaughan
a simple and fairly clean way is to run a wire over to the fuse panel on the end of the dash and then use a 'fuse tap' or 'add a fuse' into a existing slot. these are available at your local auto parts store in the fuse section.
http://www.amazon.com/Littelfuse-Add...s_auto_title_4
CB antenna - i bought the long wire, about 18', and ran it through the big hole in the firewall, back under the cab, and up between the bed and cab to a mounting bracket that i made.
https://dodgeforum.com/m_777811/mpag.../tm.htm#788722
Old Apr 27, 2008 | 01:54 PM
pcfixerpro's Avatar
pcfixerpro
Thats a mighty nice find there dhvaughan. I have mine rigged up through the cigarette lighter, but will do a more permanant solution this summer. I like how simple that sounds, because I was actually gonna run a wire from the battery in through the grommet and do it that way.... but, idk if I like the idea of runnin power next to my antenna lines. yay swr! I have a pc 78 elite cb (peaked n tuned ), co-phase harness, custom bed mount brackets (kinda like bed cap brackets), and dual 4ft firestik's.
Old Apr 27, 2008 | 03:58 PM
thumpr's Avatar
thumpr
I installed an in line fuse and a plug to fit the cig. lighter. Easy to take in and out.
Thumpr
