help with different year of motor in older truck
Old Apr 28, 2008 | 08:46 PM
christakayama's Avatar
christakayama
Default help with different year of motor in older truck
i have a 96 dodge ram v10 and motor is the shot. i have found a 2001 v10 and was wondering what would be needed for the change over.. pretty much wondering will it work and is it a direct bolt in with my trans and mounts?
Old Apr 28, 2008 | 09:07 PM
rabbler's Avatar
rabbler
Default RE: help with different year of motor in older truck
It should bolt in.
You 'might' need to swap over your old intake, injectorsand sensors.
Old Apr 28, 2008 | 09:14 PM
christakayama
ok caues im thinking about purchasing the 2001 v10 ram for the motor and trans and if the trans works i wanna use that too. but if anyone else has any input let me know.. and thanks for the input!
Old Apr 29, 2008 | 02:52 AM
froesen's Avatar
froesen
Trans won't work...your 96 will have a 47RH, the 01 will have an RE (electronic governer vs hydraulic one). To use the 01 you would have to swap the computer and do alot of wiring changes. 98 is thefirst yearfor most of the electronics changes.
Old Apr 29, 2008 | 11:46 AM
christakayama
so pretty much i have to use my trans and just change over all sensors and my intake manifold...
