is this 3 inch lift worth while?
Old May 1, 2008 | 10:24 PM
ash_009's Avatar
ash_009
Default RE: is this 3 inch lift worth while?
thats great thanks
Old May 1, 2008 | 11:08 PM
pipeking's Avatar
pipeking
i just bought this kit and am putting it on this weekend,but i got the one that is 209$ because top guns said that tha control arms are only a 1/4' bigger then stock,but i did get the tracbar bracket it was cheap it would take me a 1/2 hour to make it so for under 20$ it wwas worth it. i did want to put the spring kit on insted of the spacer but they didnt have it.it looks like a very simple mod so cant wait till the weekend.
Old May 2, 2008 | 08:39 AM
ash_009's Avatar
ash_009
Pipeking, Could you post up the links of the stuff you got so I can compare. it sounds like you will be getting out of it cheaper than I was planning on.I would love tofind a way to makethe lift a bit cheaper...that means more money left over for tires If you can take pictures of your install and post them that would be great.
Old May 2, 2008 | 11:13 AM
hometheaterman's Avatar
hometheaterman
If you want to get out of it cheap it may be cheapest to piece it together. Not really sure. You can just get a 3" coil spacer and longer shocks though then get a AAL for the rear. You don't need different control arms. IMO they look better but not htat much better than stock from what I've heard and they aren't any longer. You don't need any other brackets either. I personally like to have coils instead of spacers though but spacers seem to work fine.
