fire smell??????
Old Apr 30, 2008 | 10:34 PM
97ramkid's Avatar
97ramkid
Default fire smell??????
so out of nowhere i start up my truck put it in gear and hit the gas and right after i do it smells like something burning and theres a little bit of smoke coming from under the hood? teh smoke comes out of the passenger side headlight, it only does it while under load though like if i drive or just while we were checking i had my foot on the brake and gas to put it under load. i think it could be blowing from anywhere because the fan blows to that side....so me and my friend and his dad tried looking to see where it comes from but we cant find it and it smells really bad also any ideas on wtf might be wrong???
Old May 1, 2008 | 08:01 AM
aim4squirrels's Avatar
aim4squirrels
Default RE: fire smell??????
Did you spill any oil or coolant in the inside of the engine bay?
Do you have anything lying on the exhaust manifolds? Plugwires, hoses, oily rags?
Old May 1, 2008 | 02:58 PM
97ramkid's Avatar
97ramkid
nothing at all....i checked everything i have my wires tied up outa the way and i havent spilled anyhting on it.....its not a burning oil or rubber smell its really weird i couldnt even explain it
Old May 1, 2008 | 03:14 PM
IndyRamMan's Avatar
IndyRamMan
Did you do anything to the truck recently?
Old May 1, 2008 | 03:19 PM
mstephen89's Avatar
mstephen89
sounds like an oil leak to me.
Old May 1, 2008 | 06:48 PM
aim4squirrels
From the passenger side headlight makes me believe that you've got a coolant of tranny oil leak going into the radiator. It's also possible you've got an exhaust leak, but if you can't identify the smell, we're in for a long guessing game.
pull the tranny dipstick and smell it and see if that smells familiar.
Old May 1, 2008 | 09:00 PM
WD OPN Throttle's Avatar
WD OPN Throttle
Leak in the hose form the radiator to the overflow catch?
Old May 11, 2008 | 12:23 PM
97ramkid's Avatar
97ramkid
i have no clue where its coming from....and i havent done anything to the truck recently other then clean it.
i dont know what it smells like...its definitely something burning but i dont know what it smells like soem sort of chemical smell, and its really annoying not knowing what it is lol
Old May 11, 2008 | 05:38 PM
WD OPN Throttle
Try acquiring some of the basic automotive fluids, trans fluid, radiator fluid, motor oil, windshield washer fluid, etc. Then indvidually burn themin acontrolled setting. Tell us which one it smells like.
Old May 11, 2008 | 06:14 PM
aim4squirrels
did you clean the engine with a degreaser and not get it all washed off? WD OPN Throttle has a good Idea, you can test that pretty easily if you have a torch.
