Is the proportioning valve on a 97 the same as a 96
Old Jan 11, 2005 | 02:01 PM
1BadHawk's Avatar
1BadHawk
Default Is the proportioning valve on a 97 the same as a 96
I have a 96 ramd 2500 V-10 with abs. And I recently had all the brake lines, and master cylinder replaced. Im still having a lack of braking power to the rear wheels, which I was told by the mechanic this could be the proportioning valve. Possibley due to buildup and gung clogging it up, since their was a lot of crap in the lines prior to the brake job. I can by a proportioning valve for 20 bucks shipped off ebay from a wrecked 97 2500 also with abs. Did they use the same part for both years? otherwise a new replacement is nearly 180 bucks.
Thanks.
Old Jan 18, 2005 | 05:21 PM
indyram36's Avatar
indyram36
Default RE: Is the proportioning valve on a 97 the same as a 96
go to the parts store and they can tell you after they look it up on their computer
