whats the thing under the cap and rotor?
Old May 4, 2008 | 03:49 PM
BlueBeast2's Avatar
BlueBeast2
Default whats the thing under the cap and rotor?
Like the title asks what is the thing under the cap and rotor its a plastice thing with a wire going to it and a metal piece on the underside of it? I didn't notice it when i changed the cap and stuff before and have never seen one of them on any other car or truck. Should it be replaced with a tune up or is it fine? I wish if it needed chenged someone would have mentioned it before I went to napa to pick up my other stuff cause now they are closed
Old May 4, 2008 | 04:34 PM
BlueBeast2's Avatar
BlueBeast2
Default RE: whats the thing under the cap and rotor?
After looking around on Advance's website I found out its the "Pickup Assembly" and they are all around 60 bucks so untill it starts totally running like **** it can stay old
Old May 4, 2008 | 08:55 PM
rabbler's Avatar
rabbler
That's the sync sensor. It doesn't wear so generally you don't replace it unless it fails. Not a commonly replaced part.
Old May 5, 2008 | 02:38 AM
BlueBeast2's Avatar
BlueBeast2
What exactly does it do?
Old May 5, 2008 | 08:37 AM
aim4squirrels's Avatar
aim4squirrels
I believe that's the cam positionsensor (the round pancake looking thing with the wires on it?) It sets spark sync as the cam rotates around (well actually as distributor shaft rotates around). Twisting it around (by moving the entire distributor on it's shaft) in an old car used to allow you to advance or retard the spark to the A/F mix in the cylinders, but with the newer computer cars it doesn't work quite like that any more.
I think it's just a magnetic pickup. So like rabbler mentioned: it either works, or it doesn't.
Old May 5, 2008 | 11:00 AM
froesen's Avatar
froesen
On these trucks I think the cam sensor is used for fuel sync only, for the sequential part of the injection; the crank sensor is used for ignition timing.
Old May 5, 2008 | 11:19 AM
aim4squirrels
That's right, I had that backward in my mind. Damn sensors
