I just threw a code 1294
Old May 5, 2008 | 07:03 PM
kroffty's Avatar
kroffty
Default I just threw a code 1294
Yesterday I did a bunch of work on the old truck --> cap, rotor, water pump, thermastat, all new coolent hoses and radiator. when I cranked it up it was idleing a little high. 900rpm I thought it was just because of the tune up. but then I threw a 1294 code. Could I have nocked loose a vacume line that would do that?
Old May 5, 2008 | 07:34 PM
EricCartman's Avatar
EricCartman
Default RE: I just threw a code 1294
According to the FSM:
1294 - Target Idle Not Reached. Target RPM not achieved during drive idle condition. Possible vacuum leak or IAC (AIS) lost steps.
It could very likely be a vacuum leak. I'd double check all your hoses.
Good luck,
Cartman
Old May 5, 2008 | 08:48 PM
aim4squirrels's Avatar
aim4squirrels
did you reconnect the small vac hose that goes into the MAP sensor? You probably removed it when you changed the t stat.
Also check the two lines that go into the side of the intake manifold. One comes from the PCV, the other comes from the charcoal canister.
