Quick need help with brake controller
Old May 6, 2008 | 10:45 PM
97Ram2500's Avatar
97Ram2500
Default Quick need help with brake controller
I need to buy a brake controller for my truck, I found one that is from a 2003 ram 2500, will the plug in be the same on my 97 ram 2500? I read somewhere it was the same for 96+ is that true?
Old May 6, 2008 | 11:07 PM
matt7591's Avatar
matt7591
Default RE: Quick need help with brake controller
I use a Prodigy and it had a plug in adaptor that plugged straight into the panel that comes with trucks with the "towing package". There is only one adaptor for Dodge for Prodigy, so if the one in question also uses that panel, should be good to go.
Old May 8, 2008 | 05:24 AM
Road Racer's Avatar
Road Racer
Where is brake controller located and what does it look like? pics?
Old May 8, 2008 | 12:17 PM
mstephen89's Avatar
mstephen89
brake controller is the device that sends electrical signal to trailer brakes. They are usually located on the dash underneath the steering wheel.
Old May 8, 2008 | 01:34 PM
BlueBeast2's Avatar
BlueBeast2
I'm pretty sure all controllers are the same. If you have the towing package that plug adapter would make things a lot easier but if not any can be wired up.
Old May 9, 2008 | 10:08 AM
97Ram2500's Avatar
97Ram2500
Ok thanks, I ordered it hopefully it will be the same
