96 5.2L 318, random all cylinder misfire.
Old May 12, 2008 | 12:39 AM
Vincep's Avatar
Vincep
Default RE: 96 Dodge Ram 5.2L 318, random all cylinder misfire.
Anyone?
Old Aug 12, 2008 | 11:10 PM
redsdotson's Avatar
redsdotson
Junior Member
Default randem misfires ?
I have them also but only in gear it was not until the tranny was rebuilt ? that i would have this problem
I have changed the cmp ckp plugs wire cat roto while all these parts where needed it did not solve the problem how ever she runs great right up till you put it in gear the she dies
some thing with these trannys i had one once before do the same thing and nothing ever got fixed untill the tranny was right
so is it the stall converter or other pressure regulating ?? or do I just drop
$ 1500 on a replacement and then my head ache will go away
as for the guy who rebuilt it will see what he says in the morning
these trannys will turn a good dodge into junk
this is my second dodge to do this
good luck
Old Aug 12, 2008 | 11:20 PM
redsdotson's Avatar
redsdotson
Junior Member
ps I have not ruled out a broken wire
Old Aug 15, 2008 | 12:20 AM
NoEqual's Avatar
NoEqual
Junior Member
I had random misfire code on my 98 360 I replaced the cap rotor plugs wires coil and still no luck finally I replaced the cat aND THAT SOLVED IT. uSUALLY IT HAPPENED ONMY TRUCK AFTER A FEW HOURS OF DRIVING/STOPPING WITH THE AC ON. I originally bought a replacement cat from advance auto and I jus replaced it today with a magnaflow so hopefully it won't clog again.
Old Aug 15, 2008 | 08:58 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
If your cat clogged, then that means there is a problem with your ignition system and emission controls. When is the last time your O2 sensors were changed? They should be replaced about every 60K miles, because they can degrade in performance but not trigger a code. A catalytic converter should never, ever have to be replaced if the ignition and emissions systems are operating properly.
Old Aug 15, 2008 | 04:52 PM
Trey318's Avatar
Trey318
By the way, isn't the blinking check engine light a code?
Old Aug 16, 2008 | 12:21 PM
Visious 318's Avatar
Visious 318
Have you done a compression and leak down test? it my be such a think the engine is just flat worn out and has not enough compression in it left to run properly i have seen this in 318 with as little as 180,000 rare yes it is but when they get close to 280,000 this is very common.
Old Dec 27, 2008 | 11:35 AM
pbusa's Avatar
pbusa
I had the same problem which turned out to be a bad Catalytic Converter. I disconnected the catalytic converter and the problem went away during the test drive. Replaced it with Flow Max catalytic converter and Summit Racing muffler and the problem went away. I also replaced the O2 sensors (front and back) while I was at it.
Old Dec 27, 2008 | 07:02 PM
rmiller's Avatar
rmiller
I had a similar problem a couple months ago. It turns out the o2 sensor pigtail was soaked with oil due to a leak. Oil and dirt buildup on these can cause problems. Just a thought.
Old Jan 26, 2009 | 11:13 AM
mike landrich's Avatar
mike landrich
Has anyone ever gotten these codes only when the fuel tank is low. I've gotten them 3 times. Twice the tank was below 1/4 full and the last time it was approx 3/8. All 3 times, when I've filled the tank and cleared the codes, the truck has run fine.
I also got a transmission temp sensor code 2 of the times, so there may be some connection there.
