Power Lock switch busted...
Old Jan 12, 2005 | 02:39 PM
steve05ram360's Avatar
steve05ram360
Default Power Lock switch busted...
hey guys, my power lock switch is busted on the passenger side,
how hard is it to get the door panel off?
any link to a procedure anywhere?
Old Jan 12, 2005 | 03:20 PM
Scootr's Avatar
Scootr
Default RE: Power Lock switch busted...
Here's steps from a chilton's manual for door panel removal
Roll window down
Remove window crank (or for pwr, remove the switches)
Disengage clips holding power window/lock switch panel to door trim panel. Disengage wire connectors from switch panel, if equipped.
Remove screws holding door trim panel to door from inside arm rest pull cup.
Remove screw holding door trim panel to outside mirror frame.
Using a suitable prying tool, disengage clips holding door trim to door around perimeter of trim panel.
While holding bottom of trim panel away from door, lift upward.
Separate door trim panel from inner belt weather-strips
Disengage power outside mirror wire connector from control switch
Separate door trim panel from vehicle
or here's a link I found for door glass removal but it shows pics on how to remove the door panel...
http://dodgeram.org/tech/repair/body...placement.html
Old Jan 12, 2005 | 03:33 PM
Snafu's Avatar
Snafu
It's kinda a pain. You might be able to get the switch out without taking the whole pannel off though. I don't know, I refuse to get power windows or locks...
Old Jan 12, 2005 | 03:48 PM
steve05ram360
ORIGINAL: Scootr
...Disengage clips holding power window/lock switch panel to door trim panel. Disengage wire connectors from switch panel, if equipped.
sounds like I dont have to remove the door panel... KEWL!!! should be an easy fix then.
thanks!!!
power locks & windows are mandatory for me
