Another problem
Old May 9, 2008 | 07:45 PM
llopez4112's Avatar
llopez4112
Default Another problem
i was recently in a incident, hit the ramp with the driver corner of my 2001 dodge ram, and all my gears shifted, drive is in neutral, and i have to lift the gear handle to park to remove the key of the ignition. Those anyone know how to fix this.
Old May 9, 2008 | 08:02 PM
llopez4112's Avatar
llopez4112
Default RE: Another problem
i get very angry, when i put my car in drive and its in neutral or in park and in reverse, i have been told about a cable,but don't know much.
Old May 9, 2008 | 08:12 PM
mstephen89's Avatar
mstephen89
come down, buck snort. lol
Old May 9, 2008 | 09:26 PM
dhvaughan's Avatar
dhvaughan
look under the steering wheel for a white plastic wheel. it adjusts the tension on a small cable that goes up to the prndl indicator. turn the wheel, which moves the indicator and make it line up to the proper place.
this may be sort of a patch. the way you have to lift up on the lever is an indicator that something in the linkage may be knocked out of whack.
