Help plz..... running problem
Old May 10, 2008 | 01:19 AM
toy_builder's Avatar
toy_builder
Default Help plz..... running problem
I have 95 dodge 1500 5.9l with a a518 tranny
I need help bad !!! my dodge tranny went out aboutfive monthes ago i just had it re done
and s0 i put the tranny back in it and now it wont run...... and it ran fine before i had the trann rebuilt!!!!!!
I have checked the fuel andseems tostill b good i also seem to have plenty of fuel presure
my timings on but it acts like its offffand im getting good spark.....
The motor starts and it only runs for a couple of seconds really rough any throttle i give it it dies...
PLZZZ help confused
Old May 10, 2008 | 11:13 AM
toy_builder
Default RE: Help plz..... running problem
O i am also throwing code 37........ but in my book it dont even show i have a code 37.....
Old May 10, 2008 | 05:19 PM
jasonw's Avatar
jasonw
Site Moderator
From dodgeram.info:
Fault Code 37 - Torque converter clutch solenoid CKT or Trans temp sensor too high or low -
Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input.
It also says for 1995 Ram models, "the trailer towing package includes a transmission coolant temp sensor while the standard package doesn't. The fault code detection system is probably the same for both models. This could cause the low (no) voltage indication....no sensor to send any voltage."
Hope that helps.
Old May 10, 2008 | 11:33 PM
mstephen89's Avatar
mstephen89
wow, this is weird. If you search, my jeep has been having similar problems, I replaced the tranny and it hasn't worked right since.(my jeep has the same drivetrain as our rams). Ive changed over 750 dollars in parts and I finally took it to a mechanic. It has been there since wednesday and he hasn't figured it out yet. When he does I will be sure to add to my previous topic.
Old May 11, 2008 | 12:41 AM
Dontdodgeitramit's Avatar
Dontdodgeitramit
As far as the tranny part i really cant help but the engine thing i might. My work truck sat all winter because I work in a gravel pit an we dont make much material in the winter so thre was no need for a service truck. went to start it thrusday same problem hard start, bad idle, didnt want to run. I gave it some gas an put it in gear an drove it locally for about 20 mins an after that it starts right up an runs great
Old May 11, 2008 | 02:06 PM
toy_builder
hay guys a figured out why it would not run it was the externally c5rank sensor i must of bumped it when i put the tranny in !!!! and thanks for all the posts... now i just have to figure out why in throwing code 37............
Old May 11, 2008 | 02:21 PM
mstephen89's Avatar
mstephen89
i wish mine was that simple... good job though
