need help no power
Old May 10, 2008 | 11:04 PM
chaddyparker's Avatar
chaddyparker
Default need help no power
hi im in need of help i have a 96 ram 1500 4x4 it has 35's on it and i have no power to turn them . i put in a new motor in it last year its a 360 bored over 30 . i think i need to re gear the axles but i dont know what gears to put in . its my daily driver so i dont want it to low but i want to feel the power it should have . im waitin to play in the mud
Old May 10, 2008 | 11:16 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: need help no power
Moving you to the appropriate section for your problem...
Dusty
Old May 10, 2008 | 11:21 PM
mstephen89's Avatar
mstephen89
I would say 4.56's since its your daily driver. But if you tow or wheel regurlarly 4.88s would be a much better choice. Also if there is any chance that you will ever go bigger then 35's I would say go ahead and get the 4.88's
Old May 12, 2008 | 05:56 PM
chaddyparker
ok i stopped at a shop today to see what it would cost to regear my truck and they told me $2300.00 and they would replace all moving parts . and they also said i should go no higher than 4.10 or i wont be able to go over 55 . i dont know what to do
Old May 12, 2008 | 06:31 PM
matt7591's Avatar
matt7591
CP, I don't think that shop knows what they're talking about. Take it to a local 4wheelparts . Will probably cost about $1600-1800. They can recommend a good ratio for that truck. There are many rpm calculators on the net. The people here will know more about what RPM range works for them.
Old May 12, 2008 | 06:49 PM
jagxtype's Avatar
jagxtype
its a dodge...what do you expect ahahaha
Old May 12, 2008 | 06:50 PM
padodgeram's Avatar
padodgeram
ORIGINAL: chaddyparker
Hmmmmm .. i have 4.56 gears and it goes well past 55 mph.. amazing what some shops will say , 4.56 kinda a odd gear so if you would bail on them leaving them stuck with that gear will be harder to sell so if you bail on a 4.10 gear , then thats easier to sell then the 4.56 ... Some places want you to have at least half down payment for that reason ...
Old May 12, 2008 | 09:17 PM
chaddyparker
you have a good point about the 4.10 gear would be alot easier for them to sell. so the 4.56 feels like a good gear in your truck it gets up off the line alot better not slow like mine.
