Opinions on OBD-II Readers
Old May 12, 2008 | 02:06 PM
  #21
Muddy Creek Sam's Avatar
Muddy Creek Sam
Default RE: Opinions on OBD-II Readers
Does anyone know if you need a special reader for the ABS Controller. And does the Digimon with the Laptop work with it?
Thanks,
Sam (whose new to ABS Brakes)
Old May 12, 2008 | 08:28 PM
  #22
aim4squirrels's Avatar
aim4squirrels
Actually, the digital Odometer will hold soft codes too. I kept getting a P0351 code due to the MSD 6A that I only knew about when the truck tripped the P1281 code for the tstat. Using the SCT tuner I checked it after clearing all the codes once to see if I would get the P0351 code after the first fire up, and sure enough it was there. Turned the Truck off and checked the odometer using the key method and it was there as well.
