Transmission 46RH Troubles
Old May 15, 2008 | 05:27 PM
ozplanet's Avatar
ozplanet
Default Transmission 46RH Troubles
Ok, I have this problem with my transmission. When I accelerate the gearing go 1st-2nd-1st-3rd-4th-lock
If I WOT it will not shift into 3rd.
What I've done so far, filter change, Bands Adjusted, Check Valve removed, New TV Cable.
The Chrysler dealership told me rebuilt it. But, the transmission did not have any metal shavings in the pan when the filter was changed and the fluid was not burnt. The transmission feels fine other than the way it shifts there is no slipping.
Any other suggestions ?
Old May 15, 2008 | 06:09 PM
Dodgeman000's Avatar
Dodgeman000
Default RE: Transmission 46RH Troubles
I had a similar problem just a month ago. My truck would not shift into second gear. I tore the tranny out to have it rebuilt and it turned out to be a broken band strut. My instructor at school and the tech told me it was a common problem. Might be a good time to have it rebuilt. Good Luck
Old May 15, 2008 | 10:02 PM
ozplanet's Avatar
ozplanet
How long did it take to rebuild the tranmission and how much did it cost. It is my daily driver it cannot be down for too long
