Transmision level
Old May 16, 2008 | 12:13 AM
ibaezpardo's Avatar
ibaezpardo
Default Transmision level
Hi everybody. I have a 00' Laramie SLT,5.9. I'm checking the transmission fluid level and looks overfilled. It is between the "s" in the dipstick. I check in neutral at normal operation temperature. I have a little leak in the pan. When some days passed, the transmission begins to slipped. Inmediatly I put some fluid on it and works fine. Where is the real level in the dipstick? Is between the two marks? The XXXXXXXX zone? If so, what is happening with my transmission? Is damaged?
Old May 16, 2008 | 12:36 AM
padodgeram's Avatar
padodgeram
Default RE: Transmision level
Look at your dipstick again, rember trans fluid will expand when hot , how many known that ??? running it over filled just as worse as under filled , Mite got some damage then again maybe not time will tell...but if its running fine i wouldnt worry about it , keep an eye on the fluid..
Old May 16, 2008 | 12:44 AM
ibaezpardo's Avatar
ibaezpardo
I checked the dipstick maybe 10 times today.The same. The problem is that my wife is driven my RAM now because we sold her car and not buy a new one yet. Women never looks at the dash and she won't notice if the tranny don't shift or is running at 45 miles and 4000 RPM. I'm pretty sure she will damage my tranny if I not solve this problem. I have a quarter of fluid in my RAM and inmediatly when I notice the problem, stop the car and put some fluid. She won't do it,..for sure.. so bye RAM
Old May 16, 2008 | 12:54 AM
padodgeram's Avatar
padodgeram
ORIGINAL: ibaezpardo
Wifes are hell on cars/ trucks , when she gets home check again , or before she takes it again , check .. if the trans temp comes on , then it will not matter , it will be toast.. how much fluid are you using ? see it leaking anywhere ??
Old May 16, 2008 | 12:57 AM
ibaezpardo's Avatar
ibaezpardo
Yes, there is some leak around the pan, but tonight at 10 pm I tighted the screws again and clean the driveway. I will check tomorrow morning before she destroy my car...
Old May 16, 2008 | 04:49 AM
timsalas's Avatar
timsalas
I would drop the pan and fix it before it become a real problem. Good to change the fluid and filter as well. Its a pain to do, but it might save you problems in the future, there is a pretty good "Do it yourself" write up on this forum. Tooke me too long to do mine because I did it in my apartment complex, and they dont techniocally allow people to work on their cars there, so I had to be sneaky about it. also, transmission fluid stinks.. also, Make sure your using ATF +4
-tim
Old May 16, 2008 | 07:09 AM
ibaezpardo's Avatar
ibaezpardo
I bought this car 8 month ago and the first thing I did was replaced the transmission kit (fluid,filter,gasket etc). I'm not sure what kind of fluid I put. It was something synthetic. I choose the more expensive at Auto Zone. I will check what I put and if is necessary I will replace.
