My new dodge
Old May 22, 2008 | 10:09 PM
morpowr01's Avatar
morpowr01
Default My new dodge
So J ust baught this Dodge Ram 1500 360 and I was wondering why it gets such bad gas miles I figured it cause of the engine size but it even get **** on the highway and kinda feels like there might be some lost power???? Any advice will help??
Old May 22, 2008 | 10:37 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: My new dodge
First guess: have you checked the plenum gasket? Look down the TB (take off the air box with the filter in it) past the butterflies with a flashlight. A thin sheen is fine, but if you see oil pooled in there anywhere, you have a broken plenum gasket.
Do a search here on the forums (using the search link at top of page), you'll find a ton more info on the subject.
Old May 22, 2008 | 11:18 PM
v10power's Avatar
v10power
+1 on that.... also these things likes gas more then the companies likes to charge us.
Old May 22, 2008 | 11:39 PM
motorbrreath's Avatar
motorbrreath
just a big truck with a big motor. check the plenum and get a 14x3 round air cleaner to start with. do a search, this forum is filled with knowledge. welcome to DF
Old May 23, 2008 | 12:01 AM
HammerZ71's Avatar
HammerZ71
I had a '98 RCSB 4x4with the 5.9 bought new and after I did a lift and 35" tires (only other mods were a dual exhaust and K&N drop in) I never saw double digit mpg's unless it was strictly highway and then if I stayed under 70 mph I might've seen 11 mpg.
The LA (& later Magnum versions of it) were/are very reliable workhorses, but based on a late 60's/early 70's design, you can't expect to get the fuel economy numbers of more modern, high technology engines...
Old May 29, 2008 | 06:22 PM
lastrights's Avatar
lastrights
how many miles on it , maybe it needs a good tune up !!!
Old May 29, 2008 | 06:53 PM
jnellydodge's Avatar
jnellydodge
ORIGINAL: HammerZ71
Its true, the 5.2/5.9's are based on an old school design but they are very tough motors. Iguess dodge believed in why fix what isnt broken....for about 30 years. I only got about 13 at best with my 5.9 on the highway, my new 5.7 gets 17 consistantly.....just modern technology...how many miles are on your 360?
