Front end feels like its falling apart....Help
Old Jan 24, 2005 | 02:49 AM
DWILHA's Avatar
DWILHA
Default RE: Front end feels like its falling apart....Help
ALLWAYS TAKE A MECHANIC ALONG AND SHOW THEM THE PROBLEM, PLUS NEED MORE IMFO ON TRUCK IS IT A 4X4, IS IT RAISES OR ANYTHING?
Old Jan 24, 2005 | 01:31 PM
steve05ram360's Avatar
steve05ram360
he did mention it already... look at his sig...
Old Jan 24, 2005 | 02:11 PM
Snafu's Avatar
Snafu
ORIGINAL: 55DodgeFan
The bigger the tire the worse it will drive.......if the frontend is not upgraded to hndle it.
I don't agree. My Blazer handled better on 40" Swampers than it ever did on 33" A/T's, 35" Boggers, or 38" Swampers.
Old Jan 24, 2005 | 09:38 PM
55DodgeFan's Avatar
55DodgeFan
Maybe you had your frontend fixed to handle the bigger tires. Maybe it was because it was a chevy.
I don't know just going on my own expierience's.
79 ford 3/4 ton went from 12.50/33 to 44" ground hawgs and it did not drive or handle worth a sh*t
But my 01 ram with the bigger tires handles better now than it did with the little tires on it.
Old Jan 30, 2005 | 05:32 PM
2001offroad's Avatar
2001offroad
i have a 2001 4x4 ram with only 34000 miles and the dealership already had to replace entire front suspention and steering components. cost about 2 grand in parts/labor lucky it was under the extended warrenty and covered it all. i never even had the truck off road and its falling appart. now im having problems with my back brakes locking up [sm=headbang.gif]
Old May 26, 2005 | 07:58 PM
Tani1500's Avatar
Tani1500
just my opinion but. Its a Ford. That might have something to do with it. plus i've heard the tires you have put alot of strain on everything. just what i heard.
Old May 26, 2005 | 08:00 PM
Tani1500's Avatar
Tani1500
its probally your abs.
Old May 27, 2005 | 12:19 AM
nmason's Avatar
nmason
mine still has this a little bit also. its a 96 reg cab short box not lifted. i took it into the shop and he replaced the ptman arm and the upper ball joint i believe on the drivers side. made a worls of difference. especially through turns. ive still got some of that looseness in there, but it will be fixed later this summer when i put a lowering kit and new bushings on. ive got 125000k on my truck roght now.
