coolant leak chapter 2
Old May 27, 2008 | 04:55 AM
sstgonzo's Avatar
sstgonzo
Default coolant leak chapter 2
Well after tearing some stuff down I found out that my water pump is not leaking but there is a piece of metal behind the water pump that's attached to the block that is. I don't know what to call that piece but it looks like a pita. If anyone has and feedback on this I would love to hear it. Thanks, Aaron.
Old May 27, 2008 | 01:45 PM
timsalas's Avatar
timsalas
Default RE: coolant leak chapter 2
its called the timing chain cover
Dunno how hard its to replace haven't done it yet in a newbie
Old May 27, 2008 | 01:48 PM
charlie1935's Avatar
charlie1935
The part the water pump mounts on? If so it is the timing gear/chain cover and there is water passage's through it. Probably a good idea to replace the timing gears and chain while it's accessible. Also replace the bypass hose, the little one at the top of water pump.
Old May 27, 2008 | 04:48 PM
sstgonzo's Avatar
sstgonzo
Yea I called my mechanic today and thats the same thing he said but he would'nt be able to get to it untill Friday or so. I like to work on my truck but I don't know how big of a project this may become.
Old May 27, 2008 | 08:17 PM
aim4squirrels's Avatar
aim4squirrels
replacing the time chain gasket is easy, but takes about 1 1/2 hours extra to change. You have to pull the harmonic balancer and you'll need a special tool to pull that plus you'll need a large socket and breaker bar to get the bolt off that holds the crank pulley on. I believe its a 1 1/4 inch socket. Use that and a 24" breaker bar.
Changing the timing chain out and putting a new one on is definitely worth it. My truck runs so much smoother since I did that.
