loud pop from exhaust! tryin Seafoam
Old May 29, 2008 | 05:38 PM
2500 mopar's Avatar
2500 mopar
Default loud pop from exhaust! tryin Seafoam
hello again guys!
its been a while... about a month ago i started my truck and heard a continuous loud pop. i felt around the exhaust and discovered a split in the rear of the muffler, about 250 bucks later i now have dual exhaust with a super 44 all from summit racing. But the pop was still there so i replaced the coil and plug wires, NOPE. now i discovered its cylinder number 2's injector is sticking open and causing gas to just be continuously feed. Right now im trying the Seafoam cleaner.
will this Seafoam solve the problem or should i just by a new injector?
As always thanks!
Old May 29, 2008 | 05:43 PM
padodgeram's Avatar
padodgeram
Default RE: loud pop from exhaust! tryin Seafoam
You can try but dont think it will help , just get a new injector..
Old May 29, 2008 | 09:36 PM
aim4squirrels's Avatar
aim4squirrels
+1 if you've gotten to the point that the injector is stuck open then there's either so much crud in there you'll never get it out, or the windings are broken and it isn't going to work no matter what you dunk it in. You can probably get a used one from a salvage yard for pretty cheap.
Before you go blindly blaming the injector though, double check the harness that feeds it.
Old May 29, 2008 | 10:03 PM
dhvaughan's Avatar
dhvaughan
get a new injector before something catches on fire.
Old May 30, 2008 | 01:28 PM
2500 mopar's Avatar
2500 mopar
im positive its the injector cause when i unplug it while the engine is running it goes away, thanks guys
