5.2 just not potent
Old Jun 1, 2008 | 12:18 AM
ram833's Avatar
ram833
Junior Member
Default 5.2 just not potent
Hey quick question jus gota 5.2 extented cab 1500 ram it came with a 3" gibson cat back (not my prefernce) hyper tech programer and k&n intake its just got nothing off the line at all its kinda sad. Anyone find anything aside from forced induction that was affective?
Old Jun 1, 2008 | 12:21 AM
mstephen89's Avatar
mstephen89
Default RE: 5.2 just not potent
Yet another person who thinks that their 5,000lb truck is arace car. Man, go buy something else if you want it fast.
Also check your plenum gasket.
Old Jun 1, 2008 | 12:37 AM
Gord.'s Avatar
Gord.
My 5.2 is pretty quick (i have driven a fast car), and gets quicker and better mileage as i drive it.
I never expected it to be a race car, but it's better than I expected.
I do have the 5 speed which helps a lot though.
Old Jun 1, 2008 | 01:55 AM
ram833's Avatar
ram833
Junior Member
ok well not sure what the need to be a dick is?all i was tryin to get at is i was lookin to get alittle more torque off the line its kinda pathetic to like 20.
Old Jun 1, 2008 | 03:14 AM
Viper37's Avatar
Viper37
The 318 isnt exactly known to be a powerhouse motor.
If you want torque, get a 426. If you want good power with insane reliability, get a 318.
Old Jun 1, 2008 | 04:07 AM
jasonw's Avatar
jasonw
Site Moderator
Check your plenum gasket and see if a label with "authorized software update" appears on the computer or under the hood anywhere. This means you might have the "death flash" (retarded timing).
Do a search for the death flash or plenum here on the forums, ton of info.
Old Jun 1, 2008 | 07:38 AM
turkeyhunter1962's Avatar
turkeyhunter1962
More than likely your truck is like mine was when I purchased it new. Set up for MPG and not HP and torque. Even new, my 5.2 could hardly get out of it's own way from a dead stop. The 5.2, automatic tranny, 3.55 gears, and 5000 pound weight isjustnot a good combination to display or feel power.
Like Viper37 states though. The 318 is a great reliable and steady motor. It's in the class of the Chevy 350 V-8 and the Ford 300 inline 6. All 3 of them need at least a bullet through the block to stop them.
Old Jun 1, 2008 | 10:05 AM
aim4squirrels's Avatar
aim4squirrels
It'll never be a torque monster, but you can regear to 4.10's, add Harland Sharp roller rockers in the 1.7:1 ratio variety, Get an SCT tuner, and add some shorty headers to help out down low, and pull that Stock Fan and put in some electric fans and slot the crank sensor. That'll get it moving down there a bit and it won't feel like a sloth any more.
If you add a Fastman 50mm throttle body and a round air cleaner and open up the exhaust, you'll add some more power but it might move the torque curve up a little higher into the RPM's. Just depends on what you want.
Old Jun 1, 2008 | 10:41 AM
ram833's Avatar
ram833
Junior Member
whats the deal with this death code? i actually kick a intermitent engine light for the cam sensor but ive changed the cam and crank sensor twice it will do it here and there for a few days then be gone for two weeks it just comes and goes.
Old Jun 1, 2008 | 10:53 AM
BadHab1t's Avatar
BadHab1t
for one im sure he wasnt being a dick but u never know....i have no problems off the line never have even before i added my mods and redone 90% of my gaskets and other repairable stuff now after all thats been worked on and worked out i get a better response and i can get it quickly with my 3.55 gears which suck and im pushin 160k im sure i can do even better soon as i do some more ****....
