steering column gauge pod? HELP!
Old Jun 3, 2008 | 01:35 AM
doug15's Avatar
doug15
Default steering column gauge pod? HELP!
I just got a guage pod for my steering column and i was wondering if anyone new how to secure them. I was looking at the instructions and i still couldn't figure out how to do it. If anyone has one or knows how to securre it properly please let me know. thanks
Old Jun 3, 2008 | 01:16 PM
doug15's Avatar
doug15
Default RE: steering column gauge pod? HELP!
Old Jun 3, 2008 | 01:31 PM
Silver_Power's Avatar
Silver_Power
the pod? There are bolts on the bottom of the steering column that come all the way threw into the bottom of the top peice..which in your case is the gauge pod.
Old Jun 3, 2008 | 01:53 PM
Silver_Dodge's Avatar
Silver_Dodge
It just fits over your existing steering column. There are two ways to secure it. There is double sided sticky tape that comes with it. I tried this at first, and it didn't work very good. Or, there are plastic push-in pins that you can use. You simply install the pod, use the holes in the pod to drill small holes into your steering column, and then insert the push pins. That's how I have mine installed, and it works great. I'll find a picture for you.
Old Jun 3, 2008 | 01:54 PM
Silver_Dodge
Here's an old picture of mine. You can see the two dots on the side, those are the plastic push in pins for that side. There's two more on the other side.
[IMG]local://upfiles/9095/3D8EDEF0B22C4EACA20F59718A21F58F.jpg[/IMG]
