axle ratio w/ new tires
ok so here goes
I own a 2001 Ram 1500 5.9 4x4.
I love my truck...ever since the begining she was a dog so i tuned the engine installed a tbi spacer and a cold air intake.
They helped but it wasnt as quick as the other rams on the road.
So I get on my back and crawl under the truck and what do I find? a crappy 3.55 ratio....my answer was found
Now I ordered a set of 33's and with the truck already being kinda....sluggish...i decided i needed to swap my gears for a 4.10.(I do both highway and city driving so I decided that this would be best)
The question is.....what do I buy? I know I need one for my 9.25 axle and I see ring and pinions for sale all over. The rear end is easy you just buy the gears and the master kit and put it in...but I dont see anything for the front....How does the front end work exactly? What exactly do I have to change for my front end?
I need help soon because this problem really pisses me off....
thanks guys
thanks guys
Welcome to DF!
Check your plenum. Remove the CAI real quick, look past the butterflies and down through your throttle body. If you see oil pooled down in there, the lower plenum gasket is shot. Known to cause power loss. Also, get rid of the spacer. Does absolutely nothing for these trucks since they are port injected.
The 3.55 ratio doesn't help your get up and go, but I doubt its the sole reason if its as bad as you say it is.
Gears might solve your problems, and correcting your plenum will help. The plenum repair helped my truck, but not the low end. I have 33s and 3:55's.
You may have the deathflash though. Check your ECM for a sticker saying "authorized factory upgrade" You can check the number and see. The "Deathflash" retards your timing and kills low end. It's a band-aid from the factory to correct pinging complaints.
I don't know about your truck but all the mods and repairs I have done have not compensated for my gear tire combination. But I really don't have the cash to swap gears at this time. I DOknow thatmy truck has had several "upgrades"...[:@]
So my next purchase, before gears will be a tuner. I'd check out the SCT unit. Unlike others, its programable and upgradable. Good luck.
The front axle is a Dana 44 and you'll need a new carrier to run anything with a bigger ration than 3.55. The rear carrier will take any size gearing that they make.
TB spacer won't do a thing either die to our barrel style intake manifold. Try this instead of the CAI: https://dodgeforum.com/m_613741/tm.htm
the carrier split in the Dana 44 is between 3.73 and 3.92. the stock dana 44 carrier is for a 3.73 and numerically lower gears. in regearing to something numerically higher, then you have to get the right carrier for it, or you have to get a thick gear set. you can use the stock carrier and a thick gear set.
basically, a carrier is what your ring gear is bolted to and the axles are slid into it from the axle housing tubes. if you get a locker or something similar, that will replace a carrier, and actually is your carrier. i dont know where you can get a carrier from, i think you can get an open carrier on the internet somewhere. i have an open carrier for a Dana 44 sitting in my garage that ill let go for next to nothing if anyone is interested in it.
