Something wrong with this picture!
Old Jun 9, 2008 | 07:37 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Something wrong with this picture!
more air in means that there is more fuel burned to make the a/f ratio match again.
Old Jun 9, 2008 | 10:02 PM
CPTAFW163's Avatar
CPTAFW163
If you have 2 o2 sensors, gut your cat. Then the second 02 sensor will always read rich and your PCM will cut back on the fuel.I have that and I get 14+ MPG (with 24# injectors mind you). Bad thing is i am running lean
Old Jun 9, 2008 | 10:10 PM
aim4squirrels
Running lean isn't a good idea, it creates way too much heat.
Old Jun 9, 2008 | 10:54 PM
ct.russ's Avatar
ct.russ
all i did to mine was go with a cat back and i only get all around 12 13 thats 5.2 auto running 245 want to step up to 285 and 3 inchs of lift
ct.russ's Avatar
ct.russ
what is the deth flash ???
Old Jun 9, 2008 | 11:32 PM
360magnumram's Avatar
360magnumram
the death flash is a factory way of shutting ppl up. It was created to stop pininging compliaints....it makes your timing slow and really kills your lowend power i had it untill i retuned it with my superchips
Old Jun 10, 2008 | 01:35 AM
jasonw's Avatar
jasonw
Site Moderator
Rather than recall the trucks to fix the plenum gasket problem, they reflashed the computers to retard the timing. Kills mileage and power, but eliminates pinging caused by blown plenum gaskets.
Old Jun 10, 2008 | 05:18 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Thanks for all the replies. I have checked plenum and btw I do have a hypertech tuner.
Old Jun 10, 2008 | 05:19 AM
zman17's Avatar
zman17
And the 02 sensors are brand new when I did the magnaflow cat a couple weeks ago.
Old Jun 10, 2008 | 08:54 AM
motorbrreath's Avatar
motorbrreath
welcome to a dodge truck. i get 10 mpg.
