help new forum member-dead truck, trouble codes
Old Jun 9, 2008 | 05:13 PM
peterl23452's Avatar
peterl23452
Default help new forum member-dead truck, trouble codes
this will be the third time ive written this.
99 1500 5.2 2wd
changed the rear wheel speed sensor to fix the abs light,brake light, check engine light ,and no speedometer.
all fixed. no idiot lights are on now.
next day ...bam dead truck.
has fuel ,no spark anywhere. no voltage to coil.... checked coil in bosses identical truck...coil good
can hear fuel pump come on...have checked all fuses.
to access the codes its on,off,on,off,on,off,on right? is on run?right
dont have the money to just replace the crank sensor and see if that works, unless thats the concensus
of this forum.and it's a pita job from what i can see and read. cnat swap that outta bosses truckhe'd have a ****fit if he couldnt just hop in his truck whenever he needed to.
does the cps have a troble code or does it us the cel?
any help is appreciated. thanks
Old Jun 9, 2008 | 07:29 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: help new forum member-dead truck, trouble codes
Did your starter take a crap on you?
Old Jun 9, 2008 | 10:32 PM
Luke2233's Avatar
Luke2233
You can't do the on - off key trick on a 1999. At least it doesn't work on mine. I broke down and spent $40 bucks on a code reader.
Old Jun 10, 2008 | 11:57 AM
peterl23452
starter is good.
please help
peterl23452
can anyone else verify that i cant read codes on my 99 without a reader?
Old Jun 10, 2008 | 12:23 PM
Ramsrush's Avatar
Ramsrush
Need more information.Like what happens when you turn the key.
Old Jun 10, 2008 | 01:33 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You need a scan tool to read codes 98 and later
Old Jun 10, 2008 | 02:19 PM
peterl23452
the truck turns over ...duh jk
turns over strong... no spark
Old Jun 10, 2008 | 03:51 PM
wvjefo's Avatar
wvjefo
Peter
Spend 15 on the Hayes or Cliton Manual. Very helpful at running down problems. If you have know spark. Then you got to work back from the plugs. Is you dist & rotor good? Wire from coil to dist? Coil Good??
The manual will help a lot.A code reader is helpful too.
Jeff
Old Jun 10, 2008 | 03:53 PM
wvjefo's Avatar
wvjefo
OOPPSSS almost forgot link to manual that may help
2nd Gen Service Manual Download - AKA merry christmas thread.
https://dodgeforum.com/m_340929/tm.htm
Jeff
