sucking noise
Old Jun 9, 2008 | 05:32 PM
dodgewilltravel's Avatar
dodgewilltravel
Default sucking noise
put a 14x3 ac on my 01 318 and it seems I can hear a sucking noise, I did find a bad piece of tube on firewall,rider side, replaced and it still noisy, maybe this is normal, please advise me as what I need to do. Thanks.
Old Jun 9, 2008 | 06:22 PM
jasonw's Avatar
jasonw
Site Moderator
Default RE: sucking noise
A somewhat loud sucking noise is normal. You can hear the air being sucked into the intake.
My K&N Generation I FIPK (very similar to 14x3) on my 1995 Dakota (318) made the same noise. I was worried at first about it, but nope, its normal.
Old Jun 9, 2008 | 07:05 PM
dodgewilltravel
ok thanks, not to worry.
Old Jun 9, 2008 | 07:09 PM
aim4squirrels's Avatar
aim4squirrels
Also check thru the fins and make sure that your TB gasket isn't hanging over into the air column. It will suck but loud sucking indicates a restriction. If you trim theTB gasket or reposition it correctly you can lose a lot of the suction sound.
Old Jun 9, 2008 | 07:12 PM
dodgewilltravel
sounds good ill take a look see, Thanks.
Old Jun 9, 2008 | 07:21 PM
aim4squirrels
Sorry for the spelling, trying to get it all in before I time out.
Old Jun 10, 2008 | 01:08 PM
94Ramsey's Avatar
94Ramsey
mine does that for about 4mins when i first start it up then it goes away and it runs smoother. otherwise on the throttle its not as noisey but you can still hear it even with my exhaust. hey for 30 bucks and to loose a couple mpgi aint complaining LOL
Old Jun 10, 2008 | 01:20 PM
RM_Indy's Avatar
RM_Indy
Normal for an open element to make sucking sounds. When thegasket under themis not centered correctly they tend to whistle If the noise level changes after it warms up, could be a worn plunger on the IAC.
Old Jun 10, 2008 | 01:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
[quote]ORIGINAL: 94Ramsey
I hate the sucking noise no matter what it does for performance! And be prepared to lose MPG!
Old Jun 10, 2008 | 01:44 PM
zman17's Avatar
zman17
I'm puuting the oem Air box back on and compare.
