what part is this?
Old Jun 11, 2008 | 04:09 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: what part is this?
It is the return line. You need the special tool to disconnect towards radiator and just the right size wrenches to get it off the steel line
Old Jun 11, 2008 | 04:11 PM
zman17's Avatar
zman17
use the special tool to disconnect from rad. and quickly wipe clean and connect new hose
Old Jun 11, 2008 | 04:13 PM
zman17's Avatar
zman17
take the new hose off new trans line first.sorry
Old Jun 11, 2008 | 04:14 PM
zman17's Avatar
zman17
loosen connection towards rear from steel line
Old Jun 11, 2008 | 04:18 PM
zman17's Avatar
zman17
I have to type so quick I got the order screwwd up
Old Jun 11, 2008 | 04:19 PM
zman17's Avatar
zman17
PM me if you want more info
Old Jun 11, 2008 | 09:37 PM
TheForce55555's Avatar
TheForce55555
Cut the steel pipes right behind the fittings, buy some hose, 4 hose clampsand a tranny cooler, and install
Never have to worry about the check valve screwing your tranny up either
Old Jun 11, 2008 | 10:22 PM
Cereal Killer's Avatar
Cereal Killer
I'm sure you're aware, but I'll say it anyway. Whatever tranny fluid you lose doing this make sure you replace with ATF +4. That part is really important.
Old Jun 11, 2008 | 10:30 PM
tresvn's Avatar
tresvn
mine has a hose clamp on it, was there (and leaking) when I got the truck. I just make sure it's tight every few weeks
Old Jun 12, 2008 | 09:30 PM
CowboyBob's Avatar
CowboyBob
I'm pretty sure that hose was recalled on my 96. You may want to check before doing anything.
