AC PROBLEMS
Old Jun 12, 2008 | 11:09 PM
ALSAMP's Avatar
ALSAMP
Default AC PROBLEMS
Recently charged my A.C. it worked great, turned it on this morning and nothing but hot air, compressor not coming on, i added some more coolant and the compressor started to work but it did not get cold, is it a leak and how do you find it? this truck is really starting to **** me off, i had it for about 2 months and had to replace swaybar links, front u-joins, intermediate shaft on the steering, tranny pan and now the A.C. Im starting to regret losing my G.M.C. FOR THIS RAM.
Old Jun 13, 2008 | 06:00 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: AC PROBLEMS
What year is it ? You can buy some 134a with uv die in it. A uv light and a pair of glasses.
Old Jun 13, 2008 | 06:01 AM
zman17's Avatar
zman17
But odds are its the evap core. You cant see it so unless the leak is under the hood somewhere the die wont help.
Old Jun 13, 2008 | 06:03 AM
zman17's Avatar
zman17
I have a TIF refrigerant leak detector w/heated tip. Thats the best way but its not cheap.
Old Jun 13, 2008 | 06:04 AM
zman17's Avatar
zman17
Take it to an AC shop, let them find the leak, then you can fix it and then let them charge it back up.
Old Jun 14, 2008 | 06:49 AM
98DodgeRam1500's Avatar
98DodgeRam1500
ORIGINAL: ALSAMP
Just wait, and soon you can add these to your list....
Trac-Bar, front bearings, front axle seals, CAD vacuum lines, Tranmission rebuild, plenum gasket, and catalytic converter.
Enjoy your Turd.
