U Joint P/N check
Old Jun 15, 2008 | 04:40 PM
aim4squirrels's Avatar
aim4squirrels
Default U Joint P/N check
Could somebody double check me on this: I need 2 ujoints (no CB), the Spicer Life model is SP-5-790X for a 2001 1500 2wd. Is that what you all found?
Old Jun 15, 2008 | 04:52 PM
hometheaterman's Avatar
hometheaterman
Default RE: U Joint Press
Go with Spicer joints instead. Tried to post more but it wont let me.
Old Jun 15, 2008 | 08:46 PM
aim4squirrels
DId the research, agree on the spicers but I'll have to order them. What about the Press? I remember VWandDodge posting about the AZ Ball joint press notworking too well on the Dodge ball joints, but what about U joints?
Old Jun 15, 2008 | 09:23 PM
hometheaterman
I had a shop put Precision in mine as I needed them right then.
hometheaterman
They seem okay but I haven't had them long. I keep hearing Spicers are best.
Old Jun 15, 2008 | 09:24 PM
hometheaterman
Supposed to be stronger and I kind of wish I had gone with them. Oh well. If these wear out I probably will.
Old Jun 15, 2008 | 09:25 PM
hometheaterman
I think a lot of the ball joint presses don't have the adapter for the ball joints but I don't see why they wont work for the ujoints.
Old Jun 15, 2008 | 09:27 PM
xskylinedx's Avatar
xskylinedx
When I did my u-joints I used a table mounted vice and a socket from my socket wrench set. Can't remember what size was an exact fit but if you have a set you can size it up.
Old Jun 15, 2008 | 09:34 PM
aim4squirrels
That's the problem, I don't have a HD vice or a workbench. If it can't be done in the driveway, it doesn't get done. You can do the socket thing with a big freaking C clamp too. Maybe I'll go that route.
Old Jun 16, 2008 | 12:53 AM
hutch1973's Avatar
hutch1973
have any 2x4's laying around? That's all I used, had a guy that works at a driveline shop show me a trick.
