suspension noise, time for upgrade? Need more payload.
Old Jul 14, 2008 | 10:17 PM
Gord.'s Avatar
Gord.
Default RE: suspension noise, time for upgrade?
I would put in some airbags. They were already installed on my truck when i got it and they work great. You can't even tell they're there when they're deflated.
Old Jul 15, 2008 | 11:38 PM
hutch1973's Avatar
hutch1973
I looked into timbren springs, but they don't seem to do much to (at least they don't publish) that they increase the payload. Found some helper springs that are rated for 2500 lbs, probably go that route. I know you are not supposed to go past factory ratings, but when I do tip 2k lbs, it's litteraly for 10 miles through town. Not worried about damaging the truck for such a short run.
Old Jul 16, 2008 | 02:07 AM
jasonw's Avatar
jasonw
Site Moderator
If you look at this page...
http://www.timbren.com/aeon-double-c...on-springs.htm
And check out part A550-65, that is the spring they put in the DR1525H4 kit for a Dodge Ram 1500 4x4 built 1994-2001 and 2006-2008. I believe it has a rated capacity of 3000 lbs, bump load of 11,500 lbs. So yes, it helps a lot with heavy loads.
Old Jul 16, 2008 | 01:05 PM
hutch1973's Avatar
hutch1973
Thanks for pointing that out Jason, I somehow missed that. Believe I'll go in that direction instead now.
Old Jul 16, 2008 | 05:50 PM
jasonw's Avatar
jasonw
Site Moderator
Let us know how it turns out. I am thinking of doing that when I get some extra $$$.
Old Jul 16, 2008 | 06:29 PM
hutch1973's Avatar
hutch1973
I will, might be a bit though. Work just got nuts, and once I get the new hardwood flooring laid in the house remod this weekend, will probably be working most weekends through August. I've been preoccupied with the house stuff lately, haven't even tried to figure out my creeking up front. Louder exhaust has "fixed" it for now.
Old Jul 4, 2011 | 05:34 PM
hbarker's Avatar
hbarker
I got the firestone airbags.
Now if i would just install them,, I could tell you how well they worked.. LOL
My spring in rear seem to have a creeking noise. some days not so bad, some days terrible.. thought about soaking them down with WD40 at the joints//
Old Jul 4, 2011 | 06:15 PM
generaljr's Avatar
generaljr
in my opinion, the bags are better choice over leafs, they don't sag and if you don't need them, they can be deflated at any time.
