Front Seals...
Old Jun 16, 2008 | 12:00 PM
Dontdodgeitramit's Avatar
Dontdodgeitramit
Default Front Seals...
Dana 44 Front Seals leaking.. Which one I here theres more than one an how do I change them..
Old Jun 16, 2008 | 01:26 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: Front Seals...
It's not too bad with the right tools. You'll need 2 special tools. A case spreader and seal installer. The case spreader is not always required but sure makes it easier.
Old Jun 16, 2008 | 01:33 PM
zman17's Avatar
zman17
There is one seal on each side. Left side requires removing the diff, and right side the CAD and intermediate shaft.
Old Jun 16, 2008 | 01:35 PM
zman17's Avatar
zman17
Once the diff is out the left side is easy , but the right side you are gonna need the seal installer to do it right.
Old Jun 16, 2008 | 01:42 PM
zman17's Avatar
zman17
Iv'e done it many times so I might be making it sound easier than it really is. Once it's all apart you need too clean the inside of the tubes out also , so when you put it back together the axles don't put dirt back on the seals and in the splines.
Old Jun 16, 2008 | 01:46 PM
zman17's Avatar
zman17
There is a lot more involved in the procedure but it's not hard, just time consuming. And I wish they would fix this freakin site!
Old Jun 16, 2008 | 01:53 PM
Dontdodgeitramit
Thanxs my friend @ dodge made time for me.. 450 bucks for install.. and a bearing check.. they were done bout 50K ago..
