Am in the process of replacing my brake lines(4) two coming from the mater cyclinder and theone from the rwal valve and one from the fwal valve. They are all corroded bad, I bought the exact fit lines from the dealer and wanted to know if I have to do anything special when changing? Also when I bleed the system I plan on using a pressure type on the resevoir and I bought the abs valve depressor tool to hold open the abs valves for the front and rear when bleeding and should I do anything special when bleeding or am I on the right track? Any help would be greatful.
Also which bleeder is good to use? I have been looking at the pistol vacuum type for around $50.00 is this good to use for getting the air out of the system?
