engine problem, please help asap
Old Jun 17, 2008 | 06:23 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: engine problem, please help asap
good, you got the right one.
Old Jun 17, 2008 | 06:26 PM
aim4squirrels
It's possible the PCM is the culprit but I don't know why that would only be the case in closed loop. The ECM also reads the cam sensor and relays to the PCM.
Here's the FSM: http://www.rm-indy.com/wavefiles/2001ramsrvcmanual.zip
Old Jun 17, 2008 | 06:29 PM
elite1msmith's Avatar
elite1msmith
yeah im reading about it, ...but what would cause it to run for 20 mins, then start bogging down? to the point were it will only do 20 mph wide open
Old Jun 17, 2008 | 06:40 PM
elite1msmith
if you can get the RPM to go above 3000 then the problem will insteantly fix itself and th emotor will run smooth , of course forget about trying to do that in gear, it just bogs down
Old Jun 17, 2008 | 06:49 PM
elite1msmith
ok so i have an idea, if anyone could tell me if this is good, ......if it is a sensor, or PCM , clearly the poblem is only happening when the motor is warm, so for testing purpuses could unplug (or jump ) the temp sensor? make the pcm think its running a cold engine, if it works fine after say 40 mins of driving, then clearly it would be something related to the PCM, Verus a cam sensor or a blocked convertor would this work?
Old Jun 18, 2008 | 01:07 AM
tom01973's Avatar
tom01973
timing chain is stretched out.thats the reason for the code
Old Jun 18, 2008 | 08:33 AM
aim4squirrels
forum
Old Jun 18, 2008 | 08:34 AM
aim4squirrels
Problems
Old Jun 18, 2008 | 08:35 AM
aim4squirrels
Grrr
Old Jun 18, 2008 | 10:12 AM
elite1msmith
grrrrrrrr
