wheel bearing question
Old Jun 17, 2008 | 09:29 PM
Redneck2345's Avatar
Redneck2345
Default wheel bearing question
ok guys, I hate to post this, but I need your help. If I remember correctly I think I seen something on here about serviceable wheel bearings and serviceable ball joints, am I remember correctly? or am I just imagining things
Old Jun 17, 2008 | 10:59 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: wheel bearing question
I believe the 1500's are non serviceable (expensive sealed hub assembly). 2500 and 3500 have serviceable roller bearings. Never heard of a serviceable hub for the 1500's but if you find one, let me know.
Old Jun 17, 2008 | 11:26 PM
atcsat64's Avatar
atcsat64
Just recently had to change mine, Auto Parts Giant had the best price for 2WD, $115.83 for the hub assembly. For the same price, Autozone sold just the bearing which has to be pressed in. Good luck!
Old Jun 17, 2008 | 11:30 PM
Ramsrush's Avatar
Ramsrush
2 WD you can repack 4 WD is the expensive sealed hub assembly.
Old Jun 17, 2008 | 11:37 PM
aim4squirrels
I can't repack my 2wd. Wish I could.
Old Jun 18, 2008 | 12:08 AM
Shawn86's Avatar
Shawn86
What about tapping a zerk fitting on top of the assembly to pump 'em up? I saw somebody do it on a 2500, but I'm not sure about a 1500.
Old Jun 18, 2008 | 07:56 AM
Timb75's Avatar
Timb75
I read in the Haynes manual you can repack on 99 down 2wd models. 2000 up it's a sealed unit. I have a 2000 1500 2wd and I need to change out my drivers side front bearing. You can really feel it on right turns with all the weight shifted to the left side. Are these a pain to change out? I've never done a hub change.
Old Jun 18, 2008 | 08:00 AM
aim4squirrels
It isn't terrible, though sometimes with wheel components, rust is your biggest enemy. If you have lots of that, you can have trouble.
Old Jun 18, 2008 | 08:59 AM
Ramsrush's Avatar
Ramsrush
Yea it's not that bad, and your right moisture killed mine and I don't play in the mud.
Old Jun 18, 2008 | 11:44 AM
Timb75's Avatar
Timb75
Figures rust would be a problem and considering my truck hasbeen through a flood I'm sure it's got it's fair share of rust. I've looked it over in a few manuals and they all make the process seem straight forward. What about the nut? I read those aren't reusable either. Is it common for those to come with a hub or is that just another part to buy?
