transmission help
Old Jun 17, 2008 | 10:48 PM
kj4cwa's Avatar
kj4cwa
Default transmission help
I just replace the pressure line for my lower trans cooler line and the tranny fluid was really dark. It looked kinda like motor oil. I am not sure that my trans has ever had any service, so should I just go ahead and change the fluid? I already had to add a quart when I changed the line. Thanks.
Old Jun 17, 2008 | 10:55 PM
working4ev's Avatar
working4ev
Default RE: transmission help
i would say vary much yes change your fluid and the filter. if the fluid smells burnt you may be to late.
you should do a transmission service every 25.000 mil.
just so you know
good luck
Old Jun 17, 2008 | 11:05 PM
kj4cwa's Avatar
kj4cwa
I compared the old oil in the catch pan to the new MOPAR ATF+4 in the bottles and they smelled the same.
Old Jun 17, 2008 | 11:09 PM
kj4cwa's Avatar
kj4cwa
This is my first trans service for this truck as I am not its first owner.
Old Jun 17, 2008 | 11:12 PM
aim4squirrels's Avatar
aim4squirrels
Drop the pan, dump the oil, take out the filter and clean the magnet in the pan.
Old Jun 17, 2008 | 11:13 PM
aim4squirrels
Then reattach pan with four bolts and let it drip drain over night. The next morning dump the extra and reassemble and fill
Old Jun 17, 2008 | 11:15 PM
aim4squirrels
All told this method should take about 8 quarts, but don't just throw 8 quarts in, measr=ure with the dipstick in neutral and let the fluid heat up.
Old Jun 17, 2008 | 11:18 PM
aim4squirrels
Dump in fluid until it gets to the very bottom of the OK line then let it heat up by idling for a few min. There's actually a "nominal fluid fill curve" that you should follow based on the tranny fluid temp.
Old Jun 18, 2008 | 12:11 AM
kj4cwa's Avatar
kj4cwa
What about band adjustment? Being that I am not sure of the maintainence history I would really like to do everything that I can do to have this truck in good shape.
Old Jun 18, 2008 | 08:38 AM
aim4squirrels
If it's shifting correctly, don't mess with the bands, more harm than good can come from it if you hose it up.
