can somebody shed some light?
Old Jun 18, 2008 | 09:18 PM
sk8ordie's Avatar
sk8ordie
Default can somebody shed some light?
i dont understand how im getting 9mpg, thats right 9MPG!! u see my mods, ive changed the plugs about 2,000 mi ago. ive checked the plenum- no leaks- is there anything else i can check ? goodyear wrangler at's stock size. wires look good. havent changed the cap and rotor yet. drives strong @ 128,000 mi. bought w/ 125,000 mi on it. anyone please shed some light i refuse to beleive this is what a 2wd gets. also my grandma drives faster than i do!
Old Jun 18, 2008 | 09:33 PM
94Ramsey's Avatar
94Ramsey
Default RE: can somebody shed some light?
well lets look into specs here, are you mostly intown driving? are you making short runs alot? are you hauling anything? hows the tire pressure? what are your driving habbits like? you know these trucks werent made for fuel economy. i was towing a combined weight of 3500lbs with my ram and i got down to 7mpg with going up hills and stop & go. i know you prolly feel like your throwing your money into the tank with todays prices but basicly "and not trying to be a ***** about it" live with it or get a cheap lil 4cyl or sell it.
Old Jun 18, 2008 | 10:58 PM
sk8ordie's Avatar
sk8ordie
yes its intown but mostly freeway big city (Phoenix, az), not very many short runs, truck is empty, tires @ 80psi (tire specs), and like i said before my grandma drives faster than i do. i dont go above 2100rpm and stay @ speed limit. I know these trucks werent meant to be mpg marvels, BUT i see everyone else gets around 12mpg and they are 4x4. im thinkin that there is something wrong, but i dont know what.
Old Jun 18, 2008 | 11:03 PM
aim4squirrels's Avatar
aim4squirrels
Clogged catalytic converter???
Old Jun 18, 2008 | 11:19 PM
sk8ordie's Avatar
sk8ordie
Think so? Do you know what I can check to see if thats it?
Old Jun 19, 2008 | 12:02 AM
94Ramsey's Avatar
94Ramsey
any check engine lights? have you been getting any codes? put a white cloth overthe tail pipe while the vehicle is runningand see if your getting any black soot, thats how i checkem. honestly i dont know if there is a proper way to check them but thats how i do it.
Old Jun 19, 2008 | 12:20 AM
sk8ordie's Avatar
sk8ordie
no CEL. but does black soot mean its bad? do i have to rev it? idle it? i apreciate the info
Old Jun 19, 2008 | 01:50 AM
jasonw's Avatar
jasonw
Site Moderator
A muffler shop can usually do a pressure test on the cat to determine if its good or not. Not sure of the cost though.
If you replaced the wires but not the cap and rotor, you only did half the job. No, replacing them won't net you three MPGs, but replacing my wires, cap, and rotor got me 1 MPG.
9 is not enough. I do 95% in town driving, and rarely get under 10.5 mpg, and I have a 4x4. Run good gasoline (I like BP or Flying J, personally). There's definitely something going on.
Old Jun 19, 2008 | 02:26 AM
BlueBeast2's Avatar
BlueBeast2
thats about what i get in mine so i know how ya feel
Old Jun 19, 2008 | 07:50 AM
dhvaughan's Avatar
dhvaughan
i'd replace the front 02 sensor as it controls air/fuel mix (lean vs rich). leave the rear 02 alone, it just monitors the cat and doesn't adjust mix.
