timing on a 318
Old Jun 19, 2008 | 01:04 AM
ice_icee's Avatar
ice_icee
Default timing on a 318
is it possible to change the timing or check the timing on a 1995 obd 1 ram 4x4 w the 318?
Old Jun 19, 2008 | 07:36 AM
aim4squirrels's Avatar
aim4squirrels
Default RE: timing on a 318
It doesn't work like the old engines where you just turn the distributor.
You can buy a timing chain that has advances and retards slotted in, the PCM will partially compensate, but not totally. you cna also slot the crank sensor and move it back and forth in the bell housing to change the base timing as well. Won't net much but you can fool with it a little.
Old Jun 20, 2008 | 12:01 AM
Socha_62's Avatar
Socha_62
Why do you want to check the timing? Whats the problem that makes you think its timing.
Like he said, the computer does it.
