Truck runs like T-total $hit when cold, but when warm runs great?
Old Jun 19, 2008 | 02:56 AM
Damian's Avatar
Damian
Default Truck runs like T-total $hit when cold, but when warm runs great?
Howdy fellas. Truck is a 95, 318 5-speed.
EXTREMELY cold natured. Very rough idle for about 10 seconds at start up (then smoothes out), but the truck runs like CRAP for about 5 minutes until the engine is warm. After that, it runs perfect and doesn't miss a lick.
I've changed the plugs on the truck twice, didn't change anything. As far as I know (bought the truck used with 147K) the coil is original, distributor is original, etc etc.
I also ran a seafoam treatment through the top end and while it did blow a TON of stuff out the exhaust, it didn't clear up the problem.
Any ideas on where I should start chasing this? The truck shouldn't run like crap just because it's not up to full operating temps.
Thanks
Old Jun 19, 2008 | 07:10 AM
aim4squirrels's Avatar
aim4squirrels
Default RE: Truck runs like T-total $hit when cold, but when warm runs great?
Get a new IAC for the initial sluggish start. Do a full tuneup Champion truck plugs, wires, coil and distributor, and get a new PCV valve for insurance.
Use dielectric grease on ALL connections. You might just be chasing after moisture.
Old Jun 19, 2008 | 07:21 AM
dhvaughan's Avatar
dhvaughan
your 95 has an EGR valve. look into that too.
Old Jun 19, 2008 | 07:30 AM
MEINEKEMAN1's Avatar
MEINEKEMAN1
Im thinking IAC as well.
Old Jun 19, 2008 | 01:11 PM
Damian's Avatar
Damian
Thanks a bunch guys. I'll be replacing the IAC and EGR first to see if that helps.
Who sells a good/better coil than stock?
Old Jun 19, 2008 | 01:14 PM
aim4squirrels
I like my MSD coil I believe number 8228 is the direct replacement.
Old Jun 19, 2008 | 01:51 PM
MEINEKEMAN1
Accel also has a perf coil that bolts right up.
Old Jun 19, 2008 | 03:11 PM
steve05ram360's Avatar
steve05ram360
get original mopar cap & rotor... my experience showed me it worked the best overall.
another thing you could try is running Chevron's Techron fuel injection cleaner thru a tank of gas... (or 1/2 a tank for higher concentration). could be your injectors might be sticking some until warmed up.
next would be to clean the o2 sensor... using CRC electronic component cleaner... spray the exhaust opening holes real good & then reinstall. if it's not dead, it'll help extend it's life and improve it's performance.
Old Jun 19, 2008 | 05:55 PM
8t5gt's Avatar
8t5gt
my 02 sensor did that to mine, ran like junk then when i got on the highway it warmed up and when i got off the highway it ran awsome.
Old Jun 19, 2008 | 06:01 PM
hometheaterman's Avatar
hometheaterman
ORIGINAL: MEINEKEMAN1
Aren't there a lot of guys that say to stay away from the Accel coil? I don't know as I haven't used it. I have a stock coil but I'm a MSD fan anyway. I run MSD wires with a Napa cap and rotor.
