OK tried searching; need info
Old Jun 21, 2008 | 02:49 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: OK tried searching; need info
There are no advantages to running without a tsat! Who said that?
And BTW kowboydmac do not use too much if any at all silicone on the tstat. I recomend not using any at all. Just clean and tighten to specs.
Old Jun 23, 2008 | 03:26 PM
kowboydmac's Avatar
kowboydmac
Hmmm. I wonder if that's what has been messing me up. I tried using a very fine bead. This time, I won't try any and see what happens.
Old Jun 23, 2008 | 04:32 PM
engineblock's Avatar
engineblock
but lets say if you are running a e fan your truck will run alittle bit hotter that with a clutch fan and removing the tstat will lower the temp while running with the e fan
Old Jun 23, 2008 | 05:55 PM
aim4squirrels's Avatar
aim4squirrels
pulling the t stat will cause you truck to stay in open loop and your mileage will be horrible. You'll also throw a code P1281 engine too cold too long.
