AC compressor kicks on at 5psi runs for 5 secs and kicks off at 45psi over and over
Old Aug 13, 2014 | 08:00 AM
Brian'stime's Avatar
Brian'stime
Default Sooo
Seriously? A SIX year old thread???
People without accounts still look for info on probs not the dates...SERIOUSLY... You the sheriff here!!
Old Aug 13, 2014 | 08:26 AM
MoparMan1991's Avatar
MoparMan1991
Originally Posted by cakley
I slowly added some freon. As the pressure came up the compressor would stay on for longer. I was still well in the normal range and only used about 1/2 a 12oz can. The psi shot up to 110 and the compressor wouldn't kick back on.
Bleed some freon and no luck. I attempted to jump the compressor at the relay swith and screwed up and blew the 10amp fuse. Replaced the fuse. Bleed the freon down to 20psi. And now nothing. [X(][:@]
You know it's a federal crime (EPA Clean Air Act of 1990) to knowingly vent any refrigerant into the atmosphere? It yeilds a $25,000 fine for first time offenders, and the EPA even offers a $10,000 reward to turn in offenders.
Old Aug 13, 2014 | 09:23 AM
And there are numerous threads of exactly this nature that are FAR more recent. In fact, every summer, we see dozens just like it.
And yes, I AM the Sheriff here.
Old Aug 14, 2014 | 01:20 PM
Brian'stime
Default Huh???
So if you say you got newer threads,but the same problem then what does the age mean, if your intention is to help find a solution to their needs??? I've read many "QUOTES" from older threads that solved my problem. So...being the "(QUOTE SHERIFF)....what your real problem??? I thought we were here to help??
Old Aug 14, 2014 | 01:44 PM
we are.
I would point out that YOU found this thread via search. There was zero need to resurrect a SIX year old thread. If you found it, so can others.
