35's. i searched endlessly
hey guys. im getting 35 by 12.50s and im going to 15 inch rims. will 4.5 backspacing work? with a 10 inch rim. everyone has a different idea on what backspacing you need. i just dont want them rubbing, stickin out is fine.
I just put a set of 35x12.50 R15's on my 1500 with a 5 inch lift. I used 15x8 wheels with 4 inch backspacing. They fit beautiful and don't stick out enough that I'd need fender flares. 4.5 inch spacing would be pushing it with front brake and tie rod end clearance.
cereal thats the stock picture of my ram. havent updated it atall. i got the leveling kit with a 3 inch body on it and my wheel wells look pretty open with my 265 highway tires.
thanks alot robkdpl all i needed was someone to tell me what theywere running and if thesettup worked :P
i didint know you could run 8 inch wheels with a 12.5 tire.
ORIGINAL: 8t5gt
Just remember if you get the 10" wide wheels you're gonna need more back spacing than the the 8" wide wheels. Post some pictures when you get the tires on. What kind of tires are they?
What gear ratio you running? Some poeple say 3.55 and 35s are fine, others say it's a total dog. I just like to hear everyones opinion on the issue.
im getting 35x12.50 mickeythompson baja claws. im still deciding on rim choice.
as for gears i got the standard 3.55. we'll see how it goes im keepin my stock tires so if its absolutly horible ill switch em out until i get money for the gears. im buying the tires in about a month. the funds arnt quite there yet. but i will be posting pics of the truck now, i finally raised the front bumper after doing the body lift, man was that a bitch.
- Vince
- Vince
I originally had 10 inch wide wheels with 4 inch backspacing that I ordered first. They stuck out too far and I was going to need wide *** fender flares to keep from getting a ticket. The 8 inch wheels fit the 12.50's just fine. Most tire sites say that 8-10 inch wheel for the 12.50's. Have seen 12.50's on 7 inch wide wheels, but that is really pushing it. Just looked like they would fold under on a turn.
Trending Topics
ORIGINAL: 8t5gt
- Vince
- Vince
Just think of the wicked flex you could get offroad if you keep the 31s on there
if they made it in your size I'd recommend pro comp extreme at's.... had mine for 75k now and they are still going strong, beenin shallow mud, snow & sand and it performes well in all situations including slick pavement.
