1391 ENGINE CODE
Old Jun 26, 2008 | 12:28 PM
elite1msmith's Avatar
elite1msmith
Default 1391 ENGINE CODE
well, i pulled the timing chain cover ...1/2 inch of slop in the chain, side to side
but if u spin the camsahft to takeup the slack, its only 1/16 approx, dodge says 1/8 is the replacement interval
any other ideas sure would help if you know y i am still gettin gthis code
Old Jun 26, 2008 | 12:51 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default RE: 1391 ENGINE CODE
That code is for cam or crank position sensor "Intermitent loss of signal". And a half inch is alot. There should be almost no play! Replace it and you'll be good to go.
BTW you want to turn the crank for that check, not the cam.
Old Jun 26, 2008 | 07:35 PM
elite1msmith
i know and read a service builitin that said it is critical that the Cam senor pulse be prior to the crank pulse and the difference isonly like .2 degress or something crazy small like that.....well if there is slop in the chain the cam pulse would be late...might even be after the crank pulse
im not sure if this is gonna fix the problem....but either way....id rather replace it before the piston hits a valve
so im suppost to spin the crank? ill try that and see what it is
Old Jul 8, 2008 | 08:32 PM
elite1msmith
anybody got any ideas?
