Another bothersome regear question heh
Old Jun 27, 2008 | 09:46 AM
Wickedwiggles's Avatar
Wickedwiggles
Default Another bothersome regear question heh
YUK:YGC9.25-488 Remove YUKON GEAR - 4.88 RATIO RING & PINION GEARSET
$284.97 $284.97 ACC:R925RMKT Remove MASTER INSTALL KIT
$116.95 $116.95 YUK:YGD44-488 Remove YUKON GEAR - 4.88 RATIO RING & PINION GEARSET
$173.46 $173.46 ACC:RA28LRMKT Remove MASTER INSTALL KIT
$122.95 $122.95
Is this all i need for the re gear? as far as parts? 96dodge ram 1500, no idea what gears are in it now...but weak
Old Jun 27, 2008 | 09:52 AM
Aubrey's Avatar
Aubrey
Default RE: Another bothersome regear question heh
Does the install kit come with gaskets and marking paint? Don't forget fluids. 4.88s? Sounds like you're missing a locker or LSD too.
Old Jun 27, 2008 | 10:02 AM
Wickedwiggles
the kits come with Contains all necessary components to install a ring and pinion and/or differential case: bearings, races, seals, adjusting hardware, pinion nut, locking and pattern checking compounds -
should i wait and save up for a locker you think? I would probably just put one in the rear since I don't get to do much wheeling of course thats b/c everytime I do i break somehting heh!
Old Jun 27, 2008 | 10:16 AM
Aubrey's Avatar
Aubrey
If you're going to tear it down to put in gears, you might as well put some sort of traction aid in there. MHO
Old Jun 27, 2008 | 10:41 AM
mstephen89's Avatar
mstephen89
for the front go from :YGD44-488
to :YGD44T-488 the T is for thick
I just put 4.88's in the rear of my truck, and am waiting to do the front, because you must also buy new ring gear bolts for the front, The stock ones are 3/8 and the new ring gear need 7/16", I have been told that is you order bolts for a newer jeep yukon with a d44 in the rear that it uses the 7/16, but I have yet to order any new ones yet
Old Jun 27, 2008 | 12:04 PM
Wickedwiggles
but if i end up putting a aussilocker in the front i should not get thick gears correct?
Old Jun 27, 2008 | 12:25 PM
mstephen89's Avatar
mstephen89
as long as you get the correct carrier, also since you won't get the thick gear, I'm not sure about the bolts, I would call yukon and ask them, so that you can get the correct bolts, so that you are not waiting for them like I am
