excessive fuel usage
Old Jun 29, 2008 | 07:56 PM
phre0n's Avatar
phre0n
Default excessive fuel usage
about a week ago, i replaced my passager side wheel bearing assembly, ever since the trucks been back on the road it seems like its been using alot more fuel then it used to.. and i have no idea why...i sat outside and listened to it run, didnt hear anything different except the exhuast sounds a little differnt, and i feel no power lost or anything... it almost like ill shut the truck off with a full tank, and i go to start it.. and its sittin on like 3/4 of a tank.. i looked for leaks and found nothing... i have no idea whats up.. and starting to get expensive.... please help if possible.
Old Jun 30, 2008 | 08:37 AM
dhvaughan's Avatar
dhvaughan
Default RE: excessive fuel usage
neighbor/friend/kid siphoning gas out ?
jack up the truck and spin the wheel. does the replaced wheel bearing spin freely w/o excessing dragging other than maybe a little brake scrape ? if so, i don't think it has anything to do with your mpg.
if the truck runs like crap, smells rich, and mpg is in the crapper - precat 02 sensor might be the culprit. these should be replaced periodically, manual says every 60k but they can last a lot longer (or not).
Old Jun 30, 2008 | 02:29 PM
Dark_Horse's Avatar
Dark_Horse
Is it actually using more fuel (did you calculate MPG pre and post wheel bearing assy), or are you going purely by the gas gauge? In my Ram, the gas guage isn't reliable at all once it gets past the 3/4 mark. It usually shows E when I've only driven 200 miles, but when I go to fill up, It'll only hold 11 - 12 gallons. Maybe your gas gauge just startedacting funny like mine does?
Old Jun 30, 2008 | 02:41 PM
zman17's Avatar
zman17
Retired Moderator - RIP
It would be nice to know what year the truck is atleast!
