A/C quits blowing on acceleration?
Old Jun 30, 2008 | 08:50 AM
fhenkel's Avatar
fhenkel
Default A/C quits blowing on acceleration?
Just bought a used 1998 Ram 1500 and the A/C quits blowing anytime I use passing gear or go past half throttle from a stop? I'm been told it is a vacuum line off someplace under the dash. Anyone know which one and where to look for that line? TIA.
Old Jun 30, 2008 | 08:58 AM
dhvaughan's Avatar
dhvaughan
Default RE: A/C quits blowing on acceleration?
welcome to DF. common problem. do a search on check valve for lots of posts, some with pics. there are 2 little check valves in the vac lines. they're small about the size of a quarter, maybe 1/4" thick. one just off manifold and one closer to the firewall. if not those valves then it could be a broken line anywhere between manifold and dash controls or even over on the cruise line.
Old Jun 30, 2008 | 09:22 AM
PartsChaser's Avatar
PartsChaser
+1 on the vacuum, very common prob for our trucks.
The easiest thing is to replace the 2 small check valves on the passenger side of the engine. Just trace the vacuum lines from the manifold, should see 1 very close to the inlet, splitting into a "Y" there. Then also there is another one hanging from some very small vacuum lines on the firewall, splits into a "T" in most cases, but should be easy to find.
Cost me $7 for 2 new check valves at Autozone, fixed it. Good luck!
Old Jul 7, 2008 | 08:27 AM
fhenkel's Avatar
fhenkel
Thanks for the replays! I took a week of vacation but am back now and will check out the check valves you both mentioned.
Old Jul 7, 2008 | 09:15 AM
shott8283's Avatar
shott8283
is it a 4X4? if so my vacume lines from my tcase to my front axle rotted out.. thats where my leak was
Old Jul 7, 2008 | 04:34 PM
fhenkel's Avatar
fhenkel
No, it is a 2WD. Still checking.
Old Jul 8, 2008 | 09:56 AM
purplepills's Avatar
purplepills
I have this issue too and was wondering if you found/fixed it?
