First Dodge, need some help!
Old Jul 7, 2008 | 01:27 PM
kanner1's Avatar
kanner1
Default First Dodge, need some help!
Hey Guys, Just bought a 98 Ram 1500 SLT 2 wheel drive yesterday. Truck has 5.2 / auto trans. I have a couple of ?'s for the group. The motor in the truck is bad, cracked a rod.
1)Do I have to put back a 5.2 or can I swap in a 5.9 with no modifications. I have seen a few 5.9 locally but do not want to buy one unlessit's a bolt in!
2) Is there a big performance difference between the 5.2 & the 5.9?
3) What boltpattern are the wheels, I am looking to replace the ones on there. Willwheels off a 4x4 work on a 4x2? Anyone know how big rim/tireI can go on that truck with no extra work?
Thanks so much to anyone that helps!!
Steve
Old Jul 7, 2008 | 01:37 PM
Mowhawk's Avatar
Mowhawk
Default RE: First Dodge, need some help!
As far as i know, you can swap a 5.2 with a 5.9 just by a drop and connect. You'll have to swap your tranny too though. There is a big deference between the two engines. A lot more power with the 5.9, better towing, but 1 or 2 fewer mpg. You can put on 4x4 on a 4x2, the biggest tire that i would recommend would be a 33", you could go with a 35" but it will rub at full lock. Will need to add some spacers.
Old Jul 7, 2008 | 06:48 PM
Jr. Mechanic's Avatar
Jr. Mechanic
It is a direct drop in, however you may have to use a 5.9 PCM (Correct me if im wrong.)
You DO NOT have to change your transmission, they are both 46RE's (unless you get one from a pre 98 and it will be a 46RH.)
If you are doing it, I would put the 5.9 in, hands down.
Old Jul 7, 2008 | 07:16 PM
padodgeram's Avatar
padodgeram
Wow !!! ..... Not that much HP difference between the 5.2 and 5.9
94-95 had the RH trans OBD 1
96-01 has the RE trans OBD II
lug pattern on a 4x4 is 5 on 5.5 /2wd should be the same..
Old Jul 7, 2008 | 11:43 PM
Redneck2345's Avatar
Redneck2345
theres only 15 hp difference in a 5.2 vs 5.9 and 30 ft/lbs of tourqe difference, i dont see the big gains...
i personally challange any 5.9 to pull any of the loads I pull with my truck, and I will do the same with mine
Old Jul 7, 2008 | 11:59 PM
hometheaterman's Avatar
hometheaterman
Yeah don't you need to swap computers? As said they should use the same transmission. Honestly from what I've read there isn't a huge difference. If I had to replace it anyway I might put a 5.9L in there but if it was just for the heck of it I don't think I'd change it.
Old Jul 8, 2008 | 12:55 AM
jasonw's Avatar
jasonw
Site Moderator
First of all, I've driven both. My first truck was a little 1995 Dakota with the 5.2L, and before I bought my current Ram I test drove one with the 5.2L.
The 5.9L can out-pull and beat a 5.2L in a race any day. Don't kid yourself, Dodge offered them for a reason. I am not saying that the 5.2L is a bad engine, but come on, don't say the 5.2L can outperform an engine with documented more cubic inches, HP, and torque. The only way a 5.2L could beat a 5.9L in a Ram 1500 (of the same trim) is if you did some upgrades, but you can upgrade the 5.9L as well, so that argument is moot.
A 5.2L gets better gas mileage and, according to some mechanics, is a more reliable engine. But thats up for debate.
There are some more differences, if I remember correctly from previous threads (do a search!!!). The 5.2L is internally balanced, the 5.9L is externally balanced. You would have to swap the computer. There's also a couple other parts you'd need to swap as well, but can't remember them off the top of my head. But you do NOT need to swap the tranny.
Old Jul 8, 2008 | 02:24 AM
94Ramsey's Avatar
94Ramsey
i have also heard the 318 is a reliable engine and " me if im wrong but i've also heard a 5.2 is quicker then a 5.9. but if you want pulling power get a 5.9, if you want speed and a little better mileage get a 5.2 with a couple of light mods. if i can stick with a hemi rumble bee anythings possibe lol. but it all depends on what your going to use it for.
Old Jul 8, 2008 | 10:32 AM
Redneck2345
ORIGINAL: jason.w
I think they made the 5.9 to hang on to a relic of an engine, my uncle has the 5.9 in his dodge and if we race its dead even. Besides cubic inch's dont make a truck work, its the hp and the tourqe, and the numbers arent excatlly staggering for the 5.9, i can make up for the whopping 15 hp/30 lbs of tourqe difference just by grabbing a lower gear.
Your not going to gain much by dumping in a 360, but if thats the route you wanna go, go for it!
but i'd go bigger.....can you say......hemi?
